Problem with a Toshiba RPTV
Discussion in 'Televisions' started by jiggy, Jul 10, 2005.
  1. jiggy
    jiggy
    Jan 3, 2005
    9
    My mum had my old Toshiba 40PW8 RPTV a week or so ago and I got the dreaded phone call this morning because there's a problem.... :suicide:
    Basically on the left side of the tv the picture is totally out of focus, the right side's fine.
    I went in to the service menu where you can adjust the convergence and the green grid on the left half of the TV looks like it's in an arc and all the colours are messed up. It seems as though the green gun is totally out of alignment but can't be adjusted :confused:
    Has anyone got any ideas on things I can try?
  2. Ragnar1976
    Ragnar1976
    Sep 10, 2002
    30
    Swindon
    I had the same problem with the red gun on the right hand side, it's a workshop job i'm afraid, & if its out of warrnty I wouldn't bother, you will be better of buying a new one.
