PRoblem with a sanyo plc 8810e projector
Discussion in 'Projectors, Screens & Video Processors' started by LSTY, May 30, 2005.
  1. LSTY
    LSTY
    it turns on ok but the replace lamp light is lit but the lamp still works . it boots up till it counts down to 22 and then turns off again . I dont want to buy a new bulb until i know the problem.So does projectors not boot up without the bulb being in a 100% serviceable state ?
    any advice is welcomed , thanks
  2. stripe
    stripe
    Apr 7, 2004
    1,291
    Scotland
    +123
    It sounds like, because the bulb needs replacing it is shutting down to protect itself from any damage.
  3. Peter Parker
    Peter Parker
    Apr 6, 2001
    13,180
    UK.
    +2,721
    What stripe said.
    Some lamps explode when they reach the end of their life, so the projector is protecting itself from that. A few pjs seem to have similar ways of shutting off when the lamp reaches the end of it's life so that you have time to buy a new one before the lamp finaly goes.
    Gary.
  4. LSTY
    LSTY
    but now it only flicks on for a second and goes off and both lamp replace and temp lamps flash when its cold., i guess i have to look for a new lamp , but the decision now is it worth it as i bought it a junk sale.
    thanks
