PedroF69
Hello, I have a very strange problem with my PC, when I use the Reverb G1 pro. It is the 4th headset that was replaced by HP, in a space of 2 months. I have 4 new cables and I'm in the 4th headset. The problem: It turns off after 5 minutes, or else I have no image on the Headset, continuing to work. I have another Headset, a Lenovo P1440, which uses an Hdmi port, while the HP, uses a DisplayPort port. Lenovo works without any problem, only play sims games in VR, AMs2, Rfactor2 and DR2. in Rfactor2 use with Lenovo 270% SS, in the case of AM2 170%. Naturally when HP worked with my PC, it used only 100% SS, on SteamVr. The HP ran for 6 months, in the space of a week, started to shut down after 1 hour, then changed to 40m, 20m, 10m, and 5m. I suspect it is from my card's Display-port ports (Palit gameworks 1080ti). I use 2 monitors, 1 2560x1440 (DVI) and another 1920x1080 (hdmi), I have an hdmi / Display-port adapter that I use on the 2nd monitor. Since always, that sometimes hdmi is not detected, and I have to disconnect the cable and reconnect, sometimes, only on the 3rd or 4th time it connects, but it is usually detected when the PC starts up. Unfortunately I have no chance of testing with another card. I can play any game in the screen for hours. without any problem, the Card never pass 71ºc, with the resolution and config, of the games i play, i can max de card at 2560p (80% -99%), without any glitch or problems. I wanted to buy a new card, but not at the prices they are, I´m poor. Some advice ? Thanks
