Problem with 5.1headphones - Creative HQ2300D
Discussion in 'Headphones, Earphones & Portable Music' started by esyk, Jan 19, 2008.
  1. esyk
    esyk
    i've bought these headphones: http://www.trustedreviews.com/mp3/re...-Headphones/p1
    The phones come with a coaxial to digital cable. When i connect it to the dvd drive and decoder it works perfectly! On the other hand when i connect it to my xbox 360 or pc via optic cable it doesn't work but it should.
    The optic cable i bought was:
    http://www.worten.pt/ProductDetail.aspx?pid=03640199&oid=6|9203|9204|92 07|&c=
    The system is connected as the instructions:
    http://files2.europe.creative.com/ma...ltllingual.pdf
    Is the cable compatible?.
    Does somebody knows how to help me?
  2. esyk
    esyk
    Please, help mee :)
    Do i need any proprietary cable??
  3. C4man
    C4man
    Mar 12, 2004
    177
    28
    London
    +51
    I have the same sort of setup, however I have noticed that the optical socket the the XBOX 360 end is a little 'loose' for some cables. That end should click into place not just rest in the socket. I had to try a different cable in order for it to work properly.
    Make sure that this is the case and that you can see a red light down the cable where it plugs into the headphone processing box.
    ..and no it's not a special cable but make sure you have plugged it in to the correct socket on the top of the box, there are 2. One is for optical and the other is for analogue.
    Hope that helps
  4. RCD01
    RCD01
    Jul 8, 2007
    419
    +27
    Can you still buy these units? if so where from?
