Problem with 3d from PC via HDMI
derek500
Downloaded the LG 3D demo and it works fine on my LG Cinema 3d via USB.
However, if I play it on my PC (VLC player) connected to the TV by HDMI (I've tried all inputs) the SBS picture is displayed but only 2d>3d is available and the 3d option is greyed out.
Any ideas? Do I need to use different software?
mocca
Change your resolution to 1080p/60hz , it's greyed out because the main 3d options only work with certain resolutions ;).
mocca
Nvidia GeForce 8600M GS
Thanks. Sorted. But only get it working if I use the TV as principal screen. Before I cloned, which gave me a lower resolution on the TV.
I allways make the rule of never cloning the screen as it can create issues, i just set tv as main display so laptop or pc screen is black so i can't help any further i'm sorry :(
