Question Problem when starting to use Printer
Discussion in 'Computer Peripherals & Consumables' started by chaz, Jun 29, 2015.
  1. chaz
    chaz
    Apr 7, 2003
    4,061
    107
    sussex
    +264
    I have just bought a Cannon"PIXMA" MG7500 i works fine expect i get this on the printer screen (See Photo) how do i find these please and where I have looked in Control Panel seen printers but nothing about updating Drivers ( Sorry I am a bit thick when it comes doing things like this)
  2. chaz
    chaz
    Apr 7, 2003
    4,061
    107
    sussex
    +264
    Anybody I have now managed to find devices but the only thing I can find in the list that comes near to printers is WSD print device and it says all drivers are up to date Have I gone to the wrong device page also how do stop something appearing when turning on computer from cold in "Startup"
  3. gameofthrones30
    gameofthrones30
    Jul 1, 2015
    30
    11
    US
    If this is a new one, you could contact the technician to set it up for you
  4. chaz
    chaz
    Apr 7, 2003
    4,061
    107
    sussex
    +264
    thanks:lesson:
  5. scythefwd
    scythefwd
    Dec 3, 2014
    150
    Virginia, USA
    +13
    got into setup on the printers menu.. All it means is that there is a firmware update available for ya. Its one of the menu options, but I forget exactly in the tree its at.
  6. chaz
    chaz
    Apr 7, 2003
    4,061
    107
    sussex
    +264
    Thanks for that scythefwd it worked! Iam so used to doing updates thought the computer & not the printer. I will have to remember that. Now the second Problem if Say I want to print this page I go to print on screen it asks me to save which i do not want to do then I have go to the PDF files where the page is held then open it then print but my old Cannon I would press print and it would do it straight away with going to different places to do the print can i change this to like my old computer without going to though PDF files etc.Thanks
  7. scythefwd
    scythefwd
    Dec 3, 2014
    150
    Virginia, USA
    +13
    I haven't the foggiest whats going on with that. I have a 5520, but it prints just like any other printer i've owned.
  8. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,281
    Manchester
    +763
    This can happen if on a previous occasion you printed to PDF; after you select "print" (or Control-P) there should be an option to change printer (accessed by a little arrow which opens a dropdown menu). Change it from "PDF" to your real printer in that dropdown menu.
  9. gameofthrones30
    gameofthrones30
    Jul 1, 2015
    30
    11
    US
    Have you tried printing a text file or a word document, maybe even a webpage off the internet.
  10. gameofthrones30
    gameofthrones30
    Jul 1, 2015
    30
    11
    US
    There may be some settings that are missing which is preventing you from printing directly. But try the ones that I mentioned above and let me know, I can help you wit this.
