Problem using DVD+R with Philips DVDR70
Discussion in 'Blu-ray & DVD Players & Recorders' started by Linda Crombie, Aug 9, 2005.
  1. Linda Crombie
    Linda Crombie
    I have had my Philips DVDR70 for 18 months and apart from one small problem it has been fine. I usually record on DVD+RW discs (PC Line brand usually) and have had no problems playing them back on other equipment. Recently I started to use DVD+R discs for one-off recording and found they do not play on any other equipment, only on the Philips recorder. I have bought two different brands - JR and PC Line - but neither play back. Has anyone else had this problem??
  2. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    Did you finalise the +Rs before trying on other players? It's an option in the disc menu, and essential for compatibility.
    Otherwise I'm afraid you're taking a chance with 'PC Line' media. It's usually pretty crap stuff like Optodisc-manufactured. You may like to consider trying better +R/+RW from SVP online.
    This older site:
    http://www.digitalfaq.com/media/dvdmedia.htm
    ... gives some grading of disc media codes, and which are mirrored on the SVP site in their 'ADVINFO:' labelling of products.
  3. Ian Ball
    Ian Ball
    May 20, 2005
    199
    +6
    It's funny you should say that.
    I had the Philips dvdr880 and recorded to +rw disks without any problem for 2 years - I noticed in the manual one day that you could also record to +R disks so duly went out and bought some.
    After recording to two of them I then started to get 'empty disk' messages or 'no disk' message when in fact there was a recorded disk in.
    It never worked the same again - even when reverting back to the +rw disks.
    Bloody thing had been a good recorder up to then !!!
  4. musukebba
    musukebba
    Jan 11, 2005
    689
    +16
    As you may know, the DVDR8x0 series was plagued by a systematic manufacturing error in which the cement holding the OPU lens in place gradually changed consistency under laser power and caused misalignment. In fact, +R discs need more laser power than +RWs due to a lower dye reflectivity, and one possible explanation for your observation is that the use of +R discs accelerated that misalignment. Certainly you are not the only one to report this extreme and sudden type of failure.
    It's not necessarily related to the original post - since recordings made on faulty Philips DVDRs would usually work in other dedicated players.
  5. Linda Crombie
    Linda Crombie
    Thanks very much for your advice. I was having a senior moment as I didn't read in my user manual about finalising DVD+R discs. Have just done that to one of my PC Line discs and now it is playing on my PC!! I'm glad I didn't throw them all away.
