Problem solver needed.
Discussion in 'LCD & LED LCD TVs Forum' started by Gypsy Morph, Jan 7, 2012.
Tags:
  1. Gypsy Morph
    Gypsy Morph
    Jan 7, 2012
    4
    Hi Guys
    Need a little help, I have a Samsung LE32B450 about 2 years old when I switched it on this evening first of all the volume shot up to 100 and I couldn't turn it down so switched it off and on again, now it's as if some one is holding the channel/scroll down button down, the remote won't respond except to turn the tv on or off. I can use the buttons on the side to some extent with careful timing i was able to do a firmware upgrade via usb but cannot do the plug and play reset as the tv wont respond to the remote to type the pin in. Has anyone else come across this or know a fix? Thanks in advance.
  2. MDPlatts
    MDPlatts
    Aug 20, 2005
    288
    28
    2nd City - Manchester, UK
    +26
    Have you tried taking the batteries out of the remote (or try putting new ones in - but try it without first) - or are there any keys stuck down on the remote. I've seen weird things happen when batteries are flat - but also when there are stuck keys.
  3. Gypsy Morph
    Gypsy Morph
    Jan 7, 2012
    4
    No the remote is fine a neighbor has the same series of tv and my remote works fine on his this is defiantly an issue with the tv. Thank you anyway
  4. JayCee
    JayCee
    Jan 20, 2004
    23,183
    Lanarkshire
    +2,483
    Stuck-down buttons on the set?.
  5. Gypsy Morph
    Gypsy Morph
    Jan 7, 2012
    4
    nope there fine as well they work when used but whatever is causing it over rides the controls
  6. Gypsy Morph
    Gypsy Morph
    Jan 7, 2012
    4
    Hi again sorted it thanks to JayCee although the buttons appeared ok I took the back off and disconnected the buttons on the side of set and now works fine. cheers for all help
  7. noiseboy72
    noiseboy72
    Apr 24, 2011
    5,673
    +1,574
    Sounds like maybe they got a bit damp ?
