New to the forum and hope this is in the right place.
I need a bit of help as I've hit a brick wall with my set up.
I have an Onkyo TX-NR609 which is working fine but I recently changed my tv from an old 50" Panasonic to a Samsung TU7020 65", my issue is the Playstation 5 works fine through it with surround sound, so I know the amp is working as it will also play dvd's and blu ray but as soon as I connect my laptop I am getting no sound or picture. This was working perfectly till I changed the tv. The laptop will work if I plug directly to the tv but not when in the receiver. I am using HDMI cables. I can't understand why its not working as nothing has changed only the tv. I have the receiver into HDMI 2 eArc? I know the Onkyo is quite old and only has Arc but I thought it was backwards compatible. It could be a setting on the tv I need to change but I have not changed anything on the laptop.
Any help or advice on this matter would be greatly appreciated.
Thanks in advance,
Andy.
Thanks in advance,
Andy.
