Problem shutting down.
Discussion in 'Computer Software & Operating Systems' started by abraxus, Jan 13, 2008.
  1. abraxus
    abraxus
    Jun 6, 2006
    1,633
    63
    +216
    I have an HTPC running Windows Media Centre Edition. When ruuning everything is fine with no problems at all but whenever I shut down it seems to take ages, at least 10 mins on the "Windows is shutting down" screen before it finally switches off.
    Any ideas as to what might be causing this or how to troubleshoot it?
  2. graystreet
    graystreet
    Dec 15, 2004
    1,089
    83
    Littlehampton, West Sussex
    +261
    You could try looking in Event Viewer to see if there are any errors in there.
    While it's sitting there shutting down is there a lot of HDD activity or does it just sit there quietly ?
  3. Mr Incredible
    Mr Incredible
    Dec 2, 2003
    23,893
    2
    The Fylde Coast
    +13,533
  4. abraxus
    abraxus
    Jun 6, 2006
    1,633
    63
    +216
    Will have a look.
    It just sits there quietly.
  5. Steven
    Steven
    Senior Moderator
    Feb 1, 2005
    37,581
    +6,591
    Just before you shut down, worth having a look in task manager and see what is running. Of course google the processes before you manually close ;)
