problem recording/formatting
Discussion in 'Blu-ray & DVD Players & Recorders' started by rb5201, Sep 18, 2005.
  1. rb5201
    rb5201
    Apr 20, 2005
    2,097
    63
    essex
    +212
    Hi, I have used my panny ES-10 using TDK RW discs only for a short while, but it will now longer let me format or erase the contents of the disc. It allows me to do it but once completed still says unformatted. I have tried this on 3 different discs with the same result, is this a common problem with TDK discs or does it sound like my recorder is faulty?
    Any advice/suggestions appreciated.
    Many thanks....Rich :)
  2. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    Sorry no specific knowledge of TDK-RW discs. I have only ever used DVD-RAM discs in my two Panasonics and JVC dvd recorders. Also I have never formatted them. Just re-record over and over again. Have used DVD-R, of course, just meant have never used RW discs. Try a RAM disc and see if that is satisfactory.
