problem playing goonies - errors
Discussion in 'Movie Forum' started by mr ooops, Nov 1, 2004.
  1. mr ooops
    mr ooops
    Mar 4, 2003
    3,592
    103
    Hardwicke and Wotton
    +349
    Hi all
    Ive recently got the dvd of goonies ( i lie, ive had 7 copys now)
    basicaly every few minutes there is a real bad pause, not just a layer change pause, it lasts for a second sometimes 2, also at 1hr 29 mins and 38 seconds just as the girl has to walk the plank it pauses, picture breaks up and plays about 1 frame a second with no sound, the only way past this point is the skip button.
    At first i thought it was my dvd player (cambridge audio multi region) so i tried on the bush tv/dvd in my bedroom and a bush 1 in my sons room and a cheap dvd player i got from asda in another room, all had same fault (so i swapped the disk, 3 times in tesco's 2 times in choices and twice now in mvc)
    I have also tried on a philips / bush /daewoo / toshiba and jvc dvd player at work, all have same fault at the same times................
    Is there a known fault with these or am i just being realy unlucky??
    cheers
    jason
