Problem Playing DVD-RW On Other Machines.
Discussion in 'Blu-ray & DVD Players & Recorders' started by Chris Bickley, Aug 20, 2005.
  1. Chris Bickley
    Chris Bickley
    I have recently purchased the Panasonic DMR ES10 recorder. It works fine, but i have a small problem.
    After i have recorded a program onto a DVD-RW it plays back fine on my machine, but doesn't work on any other machine.
    If you finalize the disc first, it will play on other players, but you can't then record on it again.
    Is there anything i should do on the recorder that could change this, or is it possibly the type of disc?
    I am using a cheap brand of DVD-RW (Mr DVD).
    Thanks in advance. Chris.
  2. Mark_a
    Mark_a
    May 27, 2005
    3,064
    +612
    My Pioneer has an 'Unfinalise' command for doing just that. Does the Panasonic not have the same thing?
    Regards
    Mark
  3. Chris Bickley
    Chris Bickley
    Don't think so.
  4. iantommo
    iantommo
    Jan 24, 2005
    27
    3
    +3
    Does it have format disc in the menu?
  5. LV426
    LV426
    Administrator Staff Member
    Jul 14, 2000
    13,391
    Somewhere in South Yorkshire
    +5,780
    You can always re-format (or re-initialise) the disc for re-use. This effectively deletes everything on it, so you can't add to what's already there. As Mark_a says, you can, with a Pioneer, unfinalize which then does alow you to add more titles.
  6. mentsugi
    mentsugi
    Oct 2, 2002
    390
    28
    +29
    The sad thing about the Panny DVD-RW record function is after you finalise the DVD-RW the only way to record onto the disk again is to format which of course erases everything from the disk.
    I also have a JVC recorder and that allows you to unformat like the Pioneer, add more programs and refinalise which is much more convenient.
  7. Chris Bickley
    Chris Bickley
    Yeah, i can format the disc, to erase all the contents.
    I can finalize the disc but then i can't record on it again and it becomes a DVD-R.
  8. LV426
    LV426
    Jul 14, 2000
    13,391
    +5,780
    Errr.....no, not exactly. Whatever you do, you can't erase anything from a DVD-R. Whereas you can with RW. That's the difference.
  9. ROYOLD
    ROYOLD
    Jul 5, 2005
    3,898
    103
    Royton, Oldham. Lancs.
    +296
    DVD-RAM discs recorded on the Panasonic play back fine on my Panasonic S27 DVD Player - no need to finalise on this type of disc. They will also playback on quite a few PC DVD drives.
  10. Chris Bickley
    Chris Bickley
    I know, i'm just saying that when you finalize a DVD-RW, it becomes a DVD-R in terms of not been able to be recorded on again.
