Problem passing Dolby Digital in MCE
Discussion in 'Microsoft Windows' started by Slinkoff, Aug 10, 2005.
  1. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    If I play a DVD in WinDVD I get full glorious DD surround passed via s/pdif to my amp. It shows a DD input and it sounds great.
    If I play the same DVD in MCE using the WinDVD decoder I don't get the same, I get sound to my amp but no DD signal.
    My soundcard is a Mystique. Initially I set it to just output 2 channel sound via s/pdif. WinDVD's settings work and it still correctly sends full DD to my amp. MCE is still the same, no DD signal.
    If I change the mystique to 5.1 Dolby Live processing then WinDVD continues to work correctly and this time in MCE I get a DD signal but it sounds nothing like the true DD coming from WinDVD.
    Any ideas what's going on?
  2. jimbob19
    jimbob19
    Sep 5, 2002
    1,528
    Dunstable
    +47
    When playing DVD from within MCE - goto settings - DVD - then sound
    here change the decoder properties to spdif
    Unfortunately you will have to do this every single time you play a DVD with the windvd encoder :(
    If you use the nvidia decoder you dont have to do this , it picks it up automatically everytime
  3. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    thanks for the tip. that's a bit of a bugger though. If I use nVidia then the hardware acceleration option scrambles some of my .avi files making them unwatchable. If I disable hardware acceleration I no longer get the onscreen cursor on DVD title menus!
  4. lisag
    lisag
    Jul 14, 2004
    5,683
    Essex
    +335
    I seem to have managed to get my system pretty stable with playing back divx / xvid and dvd's with nvidia decoder... and spdif out works fine too...
    Nvidia Decoder 1.02-150
    Nvidia Display Driver 72.14
    Divx 3.11 alpha
    AC3 Filter v1.01a
    Xvid 1.1.0 Beta 2
    lisa
  5. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    thanks for that, i'll give those versions a try. Hopefully the fact I'll be using ATI Catalyst video drivers over nVidia will not affect things.
  6. jimbob19
    jimbob19
    Sep 5, 2002
    1,528
    Dunstable
    +47
    I am using an ATI 9600 pro with catalyst drivers and the nvidia dvd decoder - with h/w acceleration and have experienced no problems :)
    I was using the windvd decoder but got fed up of having to change the sound otions every time to watch a dvd with spdif to my amp
  7. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    OK, I've found the setting and now have DD within MCE and from ripped DVDs too :)
    I'm a bit confused though. I've restarted MCE, rebooted my machine, changed DVDs and the setting remains set?! I don't have to keep going back into it.
  8. jimbob19
    jimbob19
    Sep 5, 2002
    1,528
    Dunstable
    +47
    must have been thinking of powerdvd decoder - but same principle :)
    Glad its working :thumbsup:
    If you can get the nvidia decoder working I think you would find it better in terms of stability and picture quality
  9. Slinkoff
    Slinkoff
    Oct 14, 2004
    697
    28
    +24
    I've used PowerDVD, nVidia and WinDVD. To be honest, I haven't noticed anything strikingly different between them but if I was to give one a preference I would say it was WinDVD, but only slightly. I'm using an ATI card rather than an nVidia one so that might be a factor.
    I think I'll stickwith WinDVD because:
    PowerDVD - No onscreen cursor for selecting in DVD menus
    nVidia - Scrambles some .avi videos I have even after re-encoding, transcoding, couldn't get to the bottom of it. Switching off hardware acceleration fixes it but then I have the same problem as with PowerDVD, no onscreen selector.
    WinDVD - Plays everything, onscreen selector, passthru now working :)
    I wonder if there's a site somewhere that has screenshots of the same scene in a film but using each of the codecs (and possibly with both cards) to make a comparison with.
    When you judge PQ what do you look for? I tend to look at edges of people and for lines anywhere.
  10. crazyal
    crazyal
    Feb 14, 2005
    432
    Cov
    +56
    That'll be the version of ATI drivers your using - drop down to 5.4 and all should be well :)
    But if your happy with Windvd, probably no point.
