Problem or NO Problem????
Discussion in 'Home Cinema Buying & Building' started by Jonezy102, Nov 24, 2003.
  1. Jonezy102
    Jonezy102
    Hello all,
    i just got a SANYO DVD HOME THEATER SYSTEM DC-TS760. Everytime I start the machine, it makes a strange rattling noise (that i think is coming from the case), similar to de-magnetizing your Pc monitor, i was wondering if this is mearly 'how it is' with this particular dvd player, OR that there is actually a problem?? At the moment i can't tell! I tried to see if the case was loose, but it was very secure. i JUST DON'T KNOW!!
    Thanks!!
  2. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    To be honest if my player made a noise when i started it up, I would take it straight back. its not natural for a player to rattle. Take it back and exchange it.
  3. dsw182
    dsw182
    Jun 8, 2003
    755
    UK
    +9
    If it is the sound I think it is, it is normal. I have heard it on most of the AV receivers I have used.
    However, to make sure nothing is wrong - You're probably better off asking in one of the AV Hardware forums, like 'DVD players' or 'All in one systems'.
  4. Shoka
    Shoka
    Jan 10, 2002
    4,330
    Surrey
    +238
    Come to think of it, is it just like a sort of click noise, a few seconds after start up???? If it is then most amps do it, its just the internals turning on, but if its deffinatley a rattle then im not sure, as DSW182 said above, probably best in the DVDplayers forums. click the report this thread link at the bottom of one oif the posts and ask a moderator to move it for you.
  5. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,759
    2
    In a secret location with Jennifer Lawrence
    +9,551
    moved to all-in-one forum.
    Greg
  6. bonzobanana
    bonzobanana
    Aug 21, 2001
    3,449
    Yeovil
    +220
    Some systems have a speaker protection circuit that clicks in after about 2 seconds. It protects the speakers from any power on surges or interference and you'll also hear it click in 2 seconds after unplugging headphones. Its normally a nice clean and solid click noise.
