Problem mounting plasma to wall - HELP
kickingk
Him I have just started to mount tv to wall, I was attaching the brackets to the tv 3 successful one the top right just keeps turning, I think the catch in the tv is gone, The other 3 are solid tight I tugged att the bracket it looks sturdy do you think it will be OK to hang with 3 screws attachrd to the plasma,???
trekkiedj
If you had said that the bottom one was the issue, i would have said yes, because gravity would have assisted. But since it is a top bolt that wont fix, i'd say you have a problem i am afraid. I would talk to your local tv shop (an independent one is best usually) who might be able to help.
