Problem linking PTAE700 to PC with DVI
Discussion in 'Projectors, Screens & Video Processors' started by Ray, May 12, 2005.
  1. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    I've posted this in the PC forum and got a couple of pointers from Kragorn but thought someone here might also have this setup/issue.
    I've just got a PTAE700 and was checking connections (to make sure all is ok before all the cables get buried in the wall) when I came a cross a problem.
    I have a Radeon 9600 Pro with vga and dvi outputs. When I connect the PJ via vga all is fine and dandy. When I connect the PJ via DVI to VGA and use it as my second monitor all is fine also. BUT when I use my DVI/HDMI cable I get nothing on the HDMI input on the PJ.
    I have no other HDMI sources to try with the projector and don't want to play DVDs via the VGA connection.
    Any thoughts on what the problem might be ?
    Ray
  2. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    Hi Ray, how long is your dvi cable?, is it a reasonable quality one?, I have read cheap ones cant go over much distance, is the pj on before you boot up the pc?, i think it was a 9600 ati card i used many moons ago on an ae500 but that was with a £150 bettercables dvi lead, and I dont remember having to enable dvi on the card to get a picture. sorry cant be more helpful but never got round to tryin dvi on the ae700. Mike
  3. Ray
    Ray
    Oct 2, 2002
    855
    West Yorkshire
    +23
    Hi there - how you doing ?
    I've got a Lindy HDMI/HDMI cable and a DVI/HDMI adaptor to go in the PC DVI socket. I suspect it's an ATi DVI output issue rather than a cable/PJ issue but need to investigate further. Will let you know if I solve this .
    Got yourself a new plasma setup yet ?
    Ray
  4. mickey
    mickey
    Jan 30, 2003
    6,128
    manchester
    +281
    hi Ray, Not sorted anything out yet , got a living room consisting of four bare plaster walls with channels dug out all over the place looks like a bombs hit it but cant decide what to do with it yet? but wifey,s ready for a divorce :eek: :lesson: . mike
