Problem JVC GR-DX55EK
Kathy
Two issues really.
I have a broken JVC. Its not had much use but now something has gone wrong with the optics I think.
On start up it insists the lens cap is on as though its not getting enough light and the viewfinder/screen displays a cloudy grey unresolved image.
Fair enough I thought, as playback is still OK I'll use it to output through firewire for tapes from another camcorder without that facility. Surprisingly the result had quite serious lip sync problems.
If anyone has an idea on either issue I would be most grateful.
Geoffw
Hi Kathy.
Ref the lense cap, I have posted this before and it might help - Go to JVC as this is a known fault and you may be up for a free repair if you are quick. www.jvc.co.uk/knowledge-list.php?id=4#0
Good luck .... Geoff
P.s. it might be worth not mentioning the other problem ( if you get my drift )
