Problem iScans and Panny5 42" plasma -- solution?
Discussion in 'Plasma TVs' started by StooMonster, Jan 13, 2003.
  1. StooMonster
    StooMonster
    Nov 20, 2002
    4,970
    Kent
    +314
    Was browsing on US avsforums.com board, someone was complaining that they couldn't get iScan Ultra to work with their Panny plasma.
    SKoprowski replied: "I had some problems with the Iscan Ultra and my Panasonic Projector. However, it was an easy fix. Maybe this is your problem too.
    The Iscan Ultra still passes separate vertical and horizontal sync signals even though you set the Iscan to component out and SOG (sync on green). I was using an rgb cable from the Iscan to my projector - my projector was getting confused and the image was all green in 640 x 480. What I did was snap off pins 10, 13 and 14 and the projector then recognized the component out of the Iscan and works perfectly. 10, 13, and 14 carry the seperate H and v sync signals."
    http://www.avsforum.com/avs-vb/showthread.php?s=&threadid=209670
    I had heard the problem with iScan and Panny5 42" is component signal only, perhaps this is the fix? Or is the problem something else altogther?
    StooMonster
