AlexisCY
Hi all,
New member so go easy on me!
I recently purchased and successfully installed the Yamaha CRX-N470D Network receiver in the bedroom of my apartment and I am using it to listen to CDs, music from USB, Net Radio but mostly Spotify, through the receiver, mobile phone or laptop. This setup works flawlessly.
Yesterday I decided to buythe Yamaha WXAD-10 streaming adapter to connect to my existing Hi-Fi system in the Living room to extend my musical pleasure (esp. Spotify) to the rest of the apartment.
I followed the usual process:
a) Add device
b) Switch the power of WXAD-10
c) Press Connect for 5 seconds
d) The Musicast application searched and then asked me to connect to the Musicast network which I did
e) I then returned to the installation application to see that it was found and I defined it as my "Living room" device as you can see below
f) My WXAD-10 is connected to my Living room amplifier (Yamaha RX-V520RDS) using the phono cables supplied on the AUX port.
g) The WXAD-10 can be switched ON and OFF using the Multicast application so there IS communication with the unit - the power and Wifi light switch on...
h) On the Spotify application it shows "Devices available" as follows:
i) When I connect to Living Room (WXAD-10) all I get is "Connecting...." but it NEVER connects. (see below)
I HAVE TRIED EVERYTHING but I am getting nowhere and I am desperate. I have even reset everything (by removing the power on WXAD10 and reconnecting pressing the CONNECT button for 3 seconds that supposedly clears all the network settings), and re-installed but I get the exact same behaviour.
Can anyone suggest anything?
Thanks in advance
Alexis
a) Add device
Thanks in advance
Alexis
