problem finalizing on a XS32
Discussion in 'Blu-ray & DVD Players & Recorders' started by graham.myers, Jan 10, 2005.
  1. graham.myers
    graham.myers
    Mar 11, 2003
    6,221
    Leeds
    +931
    Wrote my first DVD-R this weekend (onto a datawrite x4 fuji whatsit). It was a dump of a TV programme of about 1.5 hours from my TiVo it wrote ok, played ok. Then I finalised it and it came up err=13 on the display :(
    ejected the disc, re-inserted it and it plays fine. Tried the disk on a laptop upstairs and it worked fine in that (Dell CDRW/DVD Reader).
    Took it to work and it wouldn't work on a HP laptop (CDRW/DVD Reader) and a HP desktop (DVD Writer). Put it my HP desktop (CDRW/DVD Reader) and it was fine. Its the same model of desktop, not sure (yet) about makes of drive
    any ideas to make it more compatible. :lease:
  2. TobyW
    TobyW
    Jan 6, 2005
    157
    Australia
    +3
    My experiences:-
    First, the XS32 manual says the machine won't work with x4 media. However it has worked OK for me, with a Shintaro x4 DVD-R.
    Second, I found that after finalizing a DVD-RW, the XS32 said it couldn't recognize the disc. Nevertheless the disc played OK on the XS32 and on my PC.
    Third, some older DVD drives are not able to read home-burnt DVD's, of some, or any, flavours. My 2-year-old Gateway laptop has this problem.
    Fourth, I have found that cheap unbranded DVD-R's (recorded on my PC) become unplayable soon afterwards, and turn yellow when exposed to daylight!
  3. kitschcamp
    kitschcamp
    Sep 13, 2004
    237
    28
    Australia
    +61
    You must have a different manual to me. Mine says "Discs compatible with 2x speed recording (labeled Ver.2.1/2x etc) and discs compatible with 4x speed recording (labeled Ver 2.1/4x etc) can also be used"
  4. graham.myers
    graham.myers
    Mar 11, 2003
    6,221
    Leeds
    +931
    I chose the media based on the compatability thread on here.
  5. AVFan7667
    AVFan7667
    Nov 29, 2004
    170
    16
    I have had a problem finalising -RW on a couple of occasions, but ONLY under the following circumstances.
    - Un-Finalised a -RW to add a title to it
    - Added additional title
    - Re-Finalised disc
    It came up with an error after the finalisation was complete.
    Eject disc, reinsert disc and it works fine in all devices (my PC, Laptop, stand-alone player and XS32).
    Incidentally, ALL my -R recording has been on Verbatim 8X media without a single problem.
  6. SDHoward
    SDHoward
    Nov 1, 2004
    250
    I wouldn't worry about the error, it just gets conufused ocasionally straight after it has finailized a disk. Have you noticed on a pc that if you want to verify a burnt disk the software (nero) ejects the disk first.
    Your disk has burnt fine and is properly compatable with the toshiba, its the other DVD readers its having problems with. I've had similar problems on PC burnt disks.
    The only way to make it more compatable is to try and find media that all the DVD drives like.. probably something quite expensive
