problem detecting camcorder
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by alibaba, Aug 24, 2002.
  1. alibaba
    alibaba
    I'm trying to get my PC running windows ME to detect my Panasonic NV-ds37.
    I have a OHCI card installed which is working fine.
    Everytime I connect my Camcorder, it appears in device manager with yellow exlamation mark. I have installed the latest versions of runtime from Microsoft but this doesn't help.
    Where can I find the correct driver?
    help please!
  2. Dam0
    Dam0
    I have a similar problem under 2K.
    I have no idea why, but sometimes 2K will just forget the divers. I have to move the DV card to a new PCI slot to get it working again.
    Strange.
  3. Eee-Tee
    Eee-Tee
    Sep 17, 2002
    153
    Hyde, Manchester
    Similar to the problems listed above, ive recently found that my pc doesnt aknoledge my cam when i conect the firewire lead. if it does do, when i try to use my pinnacle programe, i get the programme is not responding message.
    please help cozive got stuff to edit!!
  4. jlcrawford
    jlcrawford
    Mar 21, 2001
    491
    NE England
    +3
    Did anyone find the solution to this problem as I have the same quandry and cant find any help anywhere at the mo
  5. alibaba
    alibaba
    Hello everyone - just to let you know we've solved our problem by buying a Window XP upgrade package (about £70) - the camera was recognised straight away & we've had no problems at all
  6. kprint
    kprint
    I too had the same problem, but discovered that in studio 7 you have to provide info on the "capture device". This done , I had no more problems. It even captured without info in device manager and I'm on win98se.
  7. jlcrawford
    jlcrawford
    Mar 21, 2001
    491
    NE England
    +3
    Sorry but what software is studio 7
  8. alibaba
    alibaba
    After many months of pain trying to get my PC to recognise my camcorder I finally managed.
    I upgraded to XP and hey presto! no problems whatsoever.
    Its all I can advise to people suffering similar problems.
  9. jlcrawford
    jlcrawford
    Mar 21, 2001
    491
    NE England
    +3
  10. nkasic
    nkasic
    I have JVC GR-DVP9 and worked fine on my XP laptop, but I couldn't make it work on Win2k. It wasn't detected.
    I spent 2 weeks and discovered just last night that it works when I unplugged my network cable. I tried everything before, re-shuffled cards, re-installed software several times etc.
    At the end I replaced network card and now it works fine.
    Strange.
    Network card and connection was working fine otherwise.
    Nik
