Problem deleting files.
Discussion in 'Camcorders, Action Cams & Video Making Forum' started by shoehorn, Apr 13, 2004.
  1. shoehorn
    shoehorn
    Jul 2, 2003
    1,649
    The Garden of England
    +41
    I'm running XP home, with my capture drive set as NTFS.
    When I've finished editing and burnt to disc (or whatever), I try to delete the original captured file (in excess of 12Gb - for the hour of DV) using windows explorer.
    I'm told that the file is too big to fit in the recycle bin - so click OK.
    When I look at the properties of the capture drive, the file I've "deleted" is not there, BUT the 12Gb (or so) of disc space has not been "re-claimed".
    So let's say that my drive is 60Gb, after 4 or 5 captures and edits, I have to reformat the drive to be able to keep on using it, or else I'm told that the drive is full - even though the files I'm "deleting" (as above) don't show up any more.
    Any ideas what I'm doing wrong please -
    I'm sure (hoping!) that it's me being stupid.....!!!
    Thanks.
  2. melliott1963
    melliott1963
    Nov 27, 2001
    427
    Ilford, Essex
    +4
  3. MikeyB
    MikeyB
    Sep 24, 2001
    80
    Swindon
    Hi shoehorn,
    Try holding down the Shift key when you delete the file, this will stop Windows from trying to put the file into the recycle bin.
    Might help.
    MikeyB
