Problem connecting to my Arcam AVR100
Discussion in 'AV Receivers & Amplifiers' started by HeadBanger, Jun 12, 2001.
Tags:
  1. HeadBanger
    HeadBanger
    Sep 22, 2000
    2,251
    116
    Ashingdon
    +502
    You can purchase optical to coaxial converters which should solve your problem. I have no idea what they cost!
    Try www.hosatech.com www.fullcompass.com
    There must be UK stores that sell them - does anyone know of a UK on-line store that sells them?
  2. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
  3. le hutch
    le hutch
    I have 3 devices with digital audio out...
    Arcam DVD (coax)
    Sony PS2 (optical)
    Sony digibox (optical)
    But my Arcam reciever only has 2 x coax and 1 x optical in!! :mad: :mad: :mad:
    Is there any way to piggy back the optical connections, so I can plug 2 into 1 input??
    Is there any other solution to my simple problem??
    Ta!!
