Problem connecting PC to Panasonic PX70 37"
Bazmondo1
I am having a bit of a nightmare trying to connect my pc to my Panasonic px70 37"
I have connected the pc via a dvi-hdmi lead using hdmi slot 1 on the tv but when i select hdmi 1 with the av on the tv remote all i get is a blank screen?
I have a shuttle amd64 with a sapphire x1950pro card and a panasonic px70 37"
I belive the native res for my tv is 1024 x 768 so i selected that after right clicking desktop and changing the monitor res before unplugging my pc monitor.
Anyone have any ideas what I am doing wrong?
Baz
chrispeters
yes...u must....right click your desktop..goto your display options...and change the output of the pc to display 2 ?..it is display 2 on mine........
It is in your graphic card settings..........just click on the pic of the TV with a 2 in it...shud be ok then.
-Hitman-
I would suggest you try 720P or 1080i etc.. as these are accepted formats on the HDMI connection.
If you have a VGA port then that will accept the 1024x768 res.
Bazmondo1
How do I try 720p or 1080i settings? where do O select them as the only thing I get in display options is the slider bar to change my res?
Sorry to be such a noob!!
cheers
Baz
Bazmondo1
When i click the display two option/screen it asks if i want to extent my monitor to these display settings but then says not responding. I have not plugged th tv in at this point as I cannot even get my pc to come up on the tv so i cant change the display settings whilst on the tv. Hope that makes sense?
