Question Problem changing inputs from cold start
Discussion in 'Home Cinema Control & Remote Controls' started by JEDIBLADE, Jul 21, 2018.
Tags:
  1. JEDIBLADE
    JEDIBLADE
    Sep 24, 2002
    1,731
    Sheffield
    +171
    I have a harmony elite with hub, when I go from a cold start the amplifier (Arcam 850) won't switch to the correct input, it stays at the input last used when it was turned off. Once it's on when I change activities the input changes as expected. I've tried changing the power on delay and the input delay but no luck, any suggestions?
  2. mikelj
    mikelj
    Sep 4, 2006
    2,772
    Chorley, Lancs
    +484
    You could try adjusting the inter-device delay Fixing Inter-device Delays.
    Unfortunately, sometimes it’s a little trial and error, especially if HDMI input switching is involved.
  3. JEDIBLADE
    JEDIBLADE
    Sep 24, 2002
    1,731
    Sheffield
    +171
    Changed the inter device delay upto 3500ms, no joy:(
  4. logiciel
    logiciel
    Feb 2, 2008
    53,161
    UK
    +5,788
    Is HDMI CEC involved?
  5. JEDIBLADE
    JEDIBLADE
    Sep 24, 2002
    1,731
    Sheffield
    +171
    No its not.
  6. mikelj
    mikelj
    Sep 4, 2006
    2,772
    Chorley, Lancs
    +484
    You could try experimenting with the order in which your devices are powered on / inputs selected during the start sequences. I’d say that your aiming for your source and sink to be ready when the amp is selected to the correct input/output combination - since your amp is effectively a HDMI switch.
  7. JEDIBLADE
    JEDIBLADE
    Sep 24, 2002
    1,731
    Sheffield
    +171
    I contacted harmony and they made some changes to the power on delay, worked a treat all sorted now:clap:
