PROBLEM championship manager 00/01 on XP
Discussion in 'PC Gaming & Rigs' started by shoestring25, Jun 16, 2005.
  1. shoestring25
    shoestring25
    Feb 2, 2003
    3,333
    essex
    +208
    ive jst got a new computer and im trying to run championship manager 00/01 on windows XP i have turned on windows 95 compatability mode but when ever i try to run it it just says "there is not enough available system memory to create a game. please free up some more and try again"
    now ive got a 320 gig hard drive and gig of ram is there anyway to get this working i have tried the champ updates but to no avail.
    can anybody help? :lease:
  2. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,523
    A dystopian Grimsby
    +101
    I assume you've already read the Eidos FAQ. If not:
    Championship Manager 2 aka Championship Manager 00/01.
    "Q18. Can't run cm2 series on XP or 2k
    A18. If you only have NTFS partitions on your
    hard drive, then create a small FAT32 partition, insert a Windows 98SE bootdisk and load the game up from there. Also required are DOS mouse drivers (you may have a problem if you have a USB mouse), which will have to be loaded up each time you wish to play
    unless you amend the autoexec.bat file. Failing that, the trickier option is to install and configure a DOS emulator."
    A good dos emulator is DOSBox: http://dosbox.sourceforge.net/news.php?show_news=1
    Championship manager 2 does work on it - see: http://dosbox.sourceforge.net/comp_list.php?showID=1645&letter=C
    Hope this helps :thumbsup:
  3. shoestring25
    shoestring25
    Feb 2, 2003
    3,333
    essex
    +208
    champ 00/01 is in fact the first season update of CM3
  4. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,523
    A dystopian Grimsby
    +101
    Thanks for that - that's what I get for using google... :)
