Problem CD "SW Episode 3" and DVD32FLR / CD20RT2
Discussion in 'TAG McLaren Audio Owners' Forum' started by singletrailer, May 21, 2005.
  1. singletrailer
    singletrailer
    Aug 10, 2004
    171
    Leamington Spa
    +7
    While the DVD of the soundtrack runs fine on both TAG drives the CD does not play well at all. At many places the AV32R trys to go into HDCD mode which is always accompanied by a short stop of the music. Since it does this on both drives and on two different CDs (amazon send a second copy after me complaining) I am wondering if anybody else experienced the same fault?
  2. liam_b
    liam_b
    Apr 24, 2002
    390
    28
    Wilds of north Leicestershire
    +25
    Probably this is another disk with iffy HDCD coding, just press shift then 9 (IIRC) to switch off HDCD detection and then it should play OK.
  3. real batman
    real batman
    think youll find the tag equipment just got good taste ;)
  4. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    "DVD of the soundtrack"???? Is this disk a dual format thing (DVD/CD)?
  5. singletrailer
    singletrailer
    Aug 10, 2004
    171
    Leamington Spa
    +7
    Thanks - I will try that. How do I restore the HDCD detection?
  6. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    "DVD of the soundtrack"????? I'm curious what you mean by that?
  7. singletrailer
    singletrailer
    Aug 10, 2004
    171
    Leamington Spa
    +7
    :laugh: :laugh: :laugh:
  8. singletrailer
    singletrailer
    Aug 10, 2004
    171
    Leamington Spa
    +7
    The soundtrack consists of two discs - one CD and one DVD.
    The DVD alone is worth the money. It combines the soundtracks and pictures from all 6 movies structured in different chapters (e.g. "A Life Redeemed" - showing Anakin's journey from being met on Tatoine to being burned on Endor). Picture and sound quality are rather good.
  9. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Ah I see, have you got the latest versions of software on all the units? If all else fails turn off the HDCD as the chap suggests, I think to switch it back on again you use the same keys?
  10. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    This is a problem on a few discs out there that originally had the audio mastered in HDCD, but are then remastered with kit that doesn't preserve the HDCD info correctly. The result is semi-corrupted HDCD information that the AV will keep on attempting to lock on to (as parts look valid), only to then decide it's rubbish a few seconds later.
    As Liam mentioned the work around is temporarily disable HDCD detection on the AV processor using SHIFT+9.
  11. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    HI Steve.
    Does shift+9 turn it back on again or do we power cycle?
  12. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Yep, it's a toggle. Alternatively HDCD support is re-enabled when changing input or in/out of standby.
  13. singletrailer
    singletrailer
    Aug 10, 2004
    171
    Leamington Spa
    +7
    Thanks for the quick advice.
    Unfortunately pushing first "av" followed by "shift" (same button as 10, right?) and finally "9" does not change a thing on my AV32DP.
    Should there be any confirmation on the display?
    Do I have to enter the "menu" first?
    Are there any other buttons I have to push to select the "shift" command instead of the "10" command on that button?
    Any further advice is very much appreciated
  14. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Erm, works on mine! You can't be too slow between the "shift" and the "9" otherwise it will time out. It should show "HDCD" in big letters when you do the key sequence. Try again!
  15. singletrailer
    singletrailer
    Aug 10, 2004
    171
    Leamington Spa
    +7
    Nope "shift" + "9" does not work and does not show HDCD either.
    The only commands that work are:
    "shift" + "0" for ceiling speaker
    and
    "shift" + "THX/angle" for listening position
    :confused: :confused: :confused:
  16. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    What software version is your DP running on? This feature was only in the very latest versions of software v4.31...
  17. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Is HDCD a standard feature of all DP's?
  18. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
  19. Plump
    Plump
    Feb 22, 2002
    638
    19
    under the bridge
    No :D
    New units yes, upgraded units no
  20. Stevesky
    Stevesky
    May 13, 2004
    454
    +13
    Good point! Forgot about those upgraded things... :D Anyway, as the unit is attempting to do HDCD it must have the licence.
  21. singletrailer
    singletrailer
    Aug 10, 2004
    171
    Leamington Spa
    +7
    Here we go - my DP is running on v4.20 :clap:
    I will upgrade and come back
  22. GrahamMG
    GrahamMG
    May 8, 2004
    4,459
    UK
    +194
    Ah that old addege, "when all the difficult things have been thrashed out, the blindingly obvious only remain" :rotfl:
  23. singletrailer
    singletrailer
    Aug 10, 2004
    171
    Leamington Spa
    +7
    Upgrade accomplished (I am always amazed how quick and user friendly these upgrades work) - everything is working fine and I can finally enjoy the soudtrack :thumbsup:
    Thank you very much for your support - this community by itself makes TAG gear special.
    Does anybody know what other advantages v4.31 offers?
