Problem capturing with Studio DV
Discussion in 'Camcorders, Action Cams & Video Editing Forum' started by Ayrton, Apr 7, 2003.
  1. Ayrton
    Ayrton
    Dec 4, 2002
    629
    Leicestershire
    +21
    This is Pinnacle Studio 8 which comes with its own card. When I got it (approx Christmas) it worked straight away. I used it a lot at first and captured all the video I already had. However I havent used it in a couple of months. Now I have another couple of tapes to edit I have tried firing it up and it won't capture.
    The first time I tried it captured for about 15 seconds before the preview window went black. I could still hear sound. When I watched the captured video it hadn't worked, it stopped at the time it went black.
    I have a drive devoted to video, 20GB, there wasn't much on it but I cleared it out and defragged to make sure it was totally clean. It didn't work, when I tried to capture again this time I only got 2 seconds.
    My main hard drive which has studio 8 on it is a 20GB partition, I know Studio writes some files to it when capturing/editing so I cleared some room there too (at least 5GB free) but to no avail. Now I couldn't capture at all.
    Like I say it used to work so I removed and then reinstalled the software, this got me back to being able to capture a few seconds before the capture gave out. What I can't figure is why you get this diminishing amount of capture time even though drive space does not seem to be an issue.
    I haven't changed the hardware at all since it used to work. Although I have noticed the mouse misbehaving over the last fewdays I can't imagine how it relates to capture problems.
    Any ideas ?
    Sony TRV25E; Dell 700Mhz, 512MB, 40GB HD/7200rpm partititoned, additional 20GB/5400 for video capture; Studio DV card; PCTV Rave card; SB Live; HP optical cordless mouse; internal 56k modem (I think thats everything!)
  2. MarkE19
    MarkE19
    Aug 10, 2002
    17,131
    Rainham Essex
    +2,393
    Just a thought, but have you checked that the disk being used to capture the video footage to is the clear 20Gb drive from within Studio 8 and not your main drive?
    Mark.
  3. Ayrton
    Ayrton
    Dec 4, 2002
    629
    Leicestershire
    +21
    Yes, the main video capture is to the empty 20GB drive. The only reason I mentioned the other drive is because I know there are some things that Studio 8 writes to the drive it is stored on.
