Problem - 2 Subs 1 Sub out on Receiver??
Discussion in 'AV Receivers & Amplifiers' started by vfx, Jul 26, 2005.
  1. vfx
    vfx
    Jun 23, 2005
    28
    I recently bought a new system which came with an subwoofer...problem is I want my other one plugged in too...however my receiver only has one sub out...
    What i want to know is if I plug a y-splitter phono plug into the receiver sub out, and then plug in both subwoofers, would everything work alright?? Would the power be divided between the subs? What issues might occur?
  2. Llanowar
    Llanowar
    Jan 30, 2005
    387
    16
    Amsterdam
    Doesn't your subwoofer have an output next to the input? You can just plug in the other subwoofer on the output of your first subwoofer...
  3. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,526
    Near London.
    +208
    Using a splitter will be just fine although using a dual sub configuration can be a real pain to set up effectively. :)
  4. vfx
    vfx
    Jun 23, 2005
    28
    No unfortunately theres no Outs on the subs...
    Thanks for your help though! Now I'll proceed with the splitter.
  5. Barend
    Barend
    Apr 12, 2004
    804
    +9
    What you need is an Outlaw ICBM bass manager, it has many virtues include stereo sub outputs.
    They don't ship outside the USA, but I bought a s/h unit thru Ebay, I love it.
    Barend
  6. Mr Quint
    Mr Quint
    Jan 31, 2005
    5,553
    2
    Amity Island (Martha's Vineyard)
    +1,554
    Indeed i have used a splitter from the sub out on my Yammy Dsp-e800 and it works a treat, also using the same model of sub helps to cut down on the Pain in the A$$ setup, i set them to the same level and it works fine. :smashin:
  7. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,526
    Near London.
    +208
    Multiple subs provide many, many advantages over a single unit but getting it right has quite a steep learning curve for the uninitiated. :)
  8. Mr Quint
    Mr Quint
    Jan 31, 2005
    5,553
    2
    +1,554
  9. eviljohn2
    eviljohn2
    Jul 8, 2002
    7,526
    Near London.
    +208
  10. Mr Quint
    Mr Quint
    Jan 31, 2005
    5,553
    2
    +1,554
    Indeed friend Indeed :thumbsup:
