Probelm with Sony 32 inch Widescreen
Discussion in 'General TV Discussions Forum' started by scooby do, Mar 28, 2003.
  1. scooby do
    scooby do
    Dec 11, 2002
    1,984
    48
    +83
    Tv is a couple of years old and has a strange fault that hopefully someone on here can give me some pointers. When the Tv is first switched on the remote will control the TV for about 10 seconds after this time has gone the TV will no longer respond to the remote. Any ideas?
  2. Miles@9
    Miles@9
    Jan 17, 2003
    84
    London
    Scooby Do
    Probably stating the obvious, but it could be flat batteries in your remote.
    Got to rule out the easy ones first.
    Miles.
  3. evans
    evans
    Nov 24, 2002
    1,161
    48
    +36
    there is a way you can elimate if it is the remote or the tv by buying a universal remote and see if it works okay with that , if it does not then it is the tv at fault, if it does then it is your remote control at fault
  4. scooby do
    scooby do
    Dec 11, 2002
    1,984
    48
    +83
    definately think its the Tv as the person who's TV it is has tried another Sony remote and same thing happens!
  5. Miles@9
    Miles@9
    Jan 17, 2003
    84
    London
    Scooby Do
    Do you know if the TV is left on Standby or turned off when not in use?
    Might be worth turning off at the mains for a few minutes. Then power up again. This some times clears Logic faults in systems,
    don't know why, but there you go.
    I've got Sony 32" Wega which locks up from time to time. Doesn't respond to the remote from stand by. I just turn it off with the main power button on the set which seems to clear the problem.
    Miles.
