Probably a stupid question...(Plasma TV and Gas Fire)
Discussion in 'Plasma TVs Forum' started by Istanbul_Kop, Oct 18, 2005.
  1. Istanbul_Kop
    Istanbul_Kop
    Sep 2, 2005
    1,666
    +262
    Is it ok to mount a Plasma TV (Samsung PS-42S5HX) above a gas fire? :confused:
  2. theo cupier
    theo cupier
    Sep 18, 2004
    1,670
    63
    Amersham, Bucks
    +113
  3. Rahmorak
    Rahmorak
    Nov 30, 2004
    452
    Lake District
    +10
    There are no stupid questions, only stupid answers.
    Theo has comprehensively answered your question but in short if you have a mantle or something to keep direct heat away from the plasma you shouldn't have a problem. It might be worth checking the temp where the panel would go though just to be sure.
  4. Istanbul_Kop
    Istanbul_Kop
    Sep 2, 2005
    1,666
    +262
    Ah thanks, didn't even think of searching, thought it was an odd question.
    I'll investigate the tempeature above the fire and stuff, the mantlepiece is a huge piece of wood, so that will help, but I'll do my research before deciding.
