Probably a silly Ipod question
Discussion in 'Headphones, Earphones & Portable Music' started by petrolhead, Aug 4, 2005.
Tags:
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,490
    71
    Newcastle
    +82
    have an Ipon mini
    How do you switch it off?
    The reason I ask is that I fully charged it on the cradle tho the USB port and left it undocked. 2 days later the battery indicator is back down to its last bar and I have not used it :confused:
  2. mcfarfs
    mcfarfs
    Mar 11, 2005
    1,367
    41
    Tunbridge Wells
    +12
    Hold down the Play/Pause button for a few seconds.
  3. ADt800
    ADt800
    Leaving an iPod in a dock that isn't being powered, drains the battery big time. I leave my dock plugged into the mains and on all the time, so If I leave the iPod in the dock, there is still power to top it up. Done this for 2 years, no trouble with battery.
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,490
    71
    Newcastle
    +82
    But I dont leave it docked
  5. HMHB
    HMHB
    Nov 11, 2001
    25,561
    Nottinghamshire
    +3,894
    The player will switch itself off anyway if you don't use for 10 minutes or so. If I charge my iPod (not mini) and then leave it untouched it will usually run down after a couple of weeks.
    When you say undocked do you mean that you take it off the cradle ?
  6. extremelydodgy
    extremelydodgy
    Oct 27, 2004
    2,236
    +63
    Is it an older Mini? Updated the firmware?
