Probably A Daft Question
Discussion in 'Cables & Switches' started by SCOTT_SCOTLAND, Jun 27, 2004.
  1. SCOTT_SCOTLAND
    SCOTT_SCOTLAND
    You know how you get red white and yellow phono leads? well, i got from a shop just a black phono lead, will this work with the yellow lead as its for the picture?
    I've had to join two leads up as the one i had wasnt quite long enough, need a reply asap as its for a loft conversion and its to get a picture to the pj from a video recorder....
    Cheers in advance.....
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi Scott,
    The colour of a phono connector won't make any difference, but video cable and connectors should be 75 Ohm impedance, as against 50 Ohm for audio cable. Hope this helps.
    Steve
