Probable silly question but....
Discussion in 'Projectors, Screens & Video Processors' started by petrolhead, Apr 26, 2002.
  1. petrolhead
    petrolhead
    Mar 29, 2002
    4,871
    87
    Newcastle
    +123
    How do I mask the top and bottom of the projector lense.
    I am sure I heard from someone (Or they may have been taking the pi$$) that they used card.
    I am trying to get rid of the light spill when viewing 16:9.
    Any thoughts
  2. tahustvedt
    tahustvedt
    Feb 11, 2002
    112
    19
    In a galaxy far, far away... (Norway)
    You can't kmask the lens. The masking will be very out of focus and the edge will only be a blur on the wall/screen. You need to place the masking at least 12" from the lens for the masking to be useful.
    Try holding your hand right in front of the lens and you'll see. The only way you can mask the lens would be to mask the inside of the projector.
    Tor Arne
  3. richard plumb
    richard plumb
    Jan 27, 2002
    14,513
    Windsor
    +1,053
    best to mask the screen
  4. petrolhead
    petrolhead
    Mar 29, 2002
    4,871
    87
    Newcastle
    +123
    What could I mask the screen with then?
  5. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    By, and sometimes in, the sea
    Depends on what screen you have. Black velvet is the best 'light trap' But it would be difficult to use on a retractable screen.
  6. petrolhead
    petrolhead
    Mar 29, 2002
    4,871
    87
    Newcastle
    +123
    Yeh its a retractable. Hmm what next?
  7. Geoffc10
    Geoffc10
    Should have gone for a fixed screen maybe
  8. petrolhead
    petrolhead
    Mar 29, 2002
    4,871
    87
    Newcastle
    +123
    No can do. The screen is in front of the window.
  9. Kramer
    Kramer
    Get a 16/9 projector - no masking required :D
    Sorry, couldn't resist:D
    Black velvet is definately the best, but with your screen in front of a window (like mine), it's going to be mighty difficult.
    If you have a sudden flash of inspiration, post it here.
  10. Dubbing Mixer
    Dubbing Mixer
    Jan 27, 2002
    643
    I've thought about this a lot because I want to install a second screen in the sitting room (in front of a window). There are ways of doing it documented on AVS forum etc. but they are fairly complex and or expensive.
    About the simplest one I've come up with is a two roller system. The main screen with an appropriate length of of built in black at the bottom and a second roller with black masking for the top. Varying the masking is then just a matter of juggling the drop of the two.
    If anyone comes up with a better (simpler) answer......
