prob with HK DVD22
Discussion in 'Blu-ray & DVD Players & Recorders' started by Mep, Mar 15, 2005.
  1. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    bought one home today only to find that the remote was dead (tried other batteries too) hooked the dvd up to pw7 anyway via component and put in dvd......teh display showed it working but......no picture....now that may be because I need to do something in the settings that I can't without the remote.....and it will be going back to 7oaks tomorrow anyway ....but has anybody else experienced this?
  2. Jase
    Jase
    Mar 16, 2001
    10,956
    United Kingdom
    +3,417
    Yep. Bought one a few months ago. The remote stopped working after an hour or so but whilst it did work the cursor would whizz about the DVD menus on it's own. The player was sent back to the dealer and replaced with another which has worked flawlessly. :)
  3. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    thanks, hopefully I'll get mine sorted tomorrow.
  4. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    You're not seeing anything because you need to set the output to component in the OSD menu. Try temporarily using a composite or scart so you can a picture and change the settings.
  5. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
  6. samjet
    samjet
    Jan 1, 2005
    1,419
    38
    notts
    +5
    yes you need to go to the onscreen menu - go to AV4 and set for component
    i used the s video leads as supplied with my viera to gain access to said menu
    as regards blacks - mine performs perfectly without any problem
    hope this helps
  7. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    thanks guys....will take it back today and get them to set it it up in their demo room....hopefully it's just a case of switchin the remote from the sound of it then.
  8. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    I'm returning mine today. I think I'm going to take a Denon 1910 instead. It's a shame as I thought the HK had a lot going for it. Not being able to see the full colour range is a major drawback for me though: makes me wonder how it got reviewed so highly.
  9. GFS AV
    GFS AV
    Jan 28, 2005
    429
    16
    Don't do it. I had this and believe me it is nothing special. My Marantz 4500 is far superior in every regard.
  10. Mep
    Mep
    Dec 25, 2004
    9,712
    Surrey
    +484
    turned out to be just a dodgy remote unit.....dvd now hooked up via component to pw7 and pq is excellent! also very simple handset hack to make multi region
  11. NinjaKi11a
    NinjaKi11a
    Sep 7, 2003
    314
    16
    The Marantz won't do NTSC progressive, which is all that my set will accept so it's not an option. I loaned a 1910 and actually liked the picture in NTSC but it wouldn't convert from PAL so it's no good to me. Just got an HK DVD25 - I haven't played a movie yet, but it looks like it'll do the job.
