Prob loading Server 2000 with XP
Discussion in 'Desktop & Laptop Computers Forum' started by chalkdust, Nov 6, 2004.
  1. chalkdust
    chalkdust
    Jul 8, 2003
    751
    +22
    Can anyone help. I am currently running win XP but want to load Win Server 2000 on my pc onto a partition separate from xp. When I load the server disc up it says I am running a more recent version of windows and doesn't allow me to install it. How would I go about creating a partition that Server would load to. I need Server for a course I am about to do in case you were wondering why.
  2. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Don't you love Microsoft and their backward compatibility .. there's no technical reason for this restriction, it's just bloody-mindedness on their part, the XP bootloader would be perfectly capable of booting 2K as well as XP since you can install XP after 2K I think.
    Off hand the only thing I can think of is to use Partition Magic & Boot Magic, hide your XP partition and then try installing 2K. Even that may not work if the 2K installer sniffs hidden partitions, which there's no reason for it to do but who knows. If you're into Linux then Lilo or Grub would work just as well to manage the partitions and boot.
  3. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,477
    +6,918
    I'd be inclined to keep the 2 completely seperate, especially if you're going to be "playing" with W2k. If you have a free 5.25" bay I suggest buying a couple of removeable cradles (like this) & a low capacity HDD & just swap drives. That way you can play around & experiment with W2k with no risk whatsoever to your existing setup.
  4. chalkdust
    chalkdust
    Jul 8, 2003
    751
    +22
    Thanks for the replies, had hoped I might get away without any 3rd party software or tinkering around inside but looks like I have little choice. :rolleyes:
  5. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,477
    +6,918
    If you don't want to open the PC then a cheap 2nd hand unit may be an alternative. I can point you to 300MHz Celeron boxes for £44 delivered but obviously W2k Server isn't exactly going to fly on it. Would allow you to network the 2 boxes for more playing though.
  6. chalkdust
    chalkdust
    Jul 8, 2003
    751
    +22
    Thanks crocodile, that would be much appreciated.
  7. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,477
    +6,918
    Cheap desktops here. A cheap all-in-one KVM switch & you're in business.
  8. chalkdust
    chalkdust
    Jul 8, 2003
    751
    +22
    thanks crocodile, much appreciated.
  9. KraGorn
    KraGorn
    Aug 30, 2003
    4,745
    68
    Warrington
    +27
    Just a note of caution, that disk is on the small side, you'll have to watch which 2K components you install or else you'll need to upgrade it.
  10. bond007
    bond007
    Aug 25, 2003
    90
    +5
    You could always try using vm-ware or virtual pc and just run server in xp.
    Oh and also it would also be better for you if you are mucking about with server and screw it up as you will be able to go back to a restore point that you create within a few seconds.
