McTrucky
Established Member
Hi all,
I have three Proac Tablettes at the front
A pair of B&W 685s2 as the wides
A pair of B&W M1 as rears
BK 400 sub
All plugged into a Pioneer SC77LX
I am happy with this, ish. But wonder if a centre with a tweeter central to a pair of mid range cones would be better than a two way lying on its side. Would a wider three way set up be better? It would certainly look better..
If I could pick up a decent Proac centre second hand I would, but they are like hen's teeth. But there are plenty B&Ws available on the 'bay.
So, would it be a mistake to mix and match with a B&W front?
Would getting three B&W across the front be a better bet? But what would hold a candle to the Proacs that were a similar small size (need 'discreet' speakers at the fron due to positioning - the 685s would be too large as fronts).
BK 400 sub
