Pro-V output to a projector and a monitor?
Discussion in 'Projectors, Screens & Video Processors' started by Bert Coules, Mar 15, 2003.
  1. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Is it technically feasible to run the output of a Pro-V through a VGA splitter or switch in order to feed both a projector and a monitor?
    A switch would do, since I don't want to run the projector (an AE100) and the monitor simultaneously; but would putting the signal through a switch degrade the progressive-scan output to the projector?
    I know that this can be done with an HCPC, but I don't want to go down that route.
    Thanks in advance.
    Bert
    www.bertcoules.co.uk
  2. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    All the cheaper vga splitters will degrade the signal noticably on a ae100 size picture.
    To get a splitter that wont degrade the signal you'll probably have to spend nearly as much as the proV itself.:(
  3. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Thanks, John.
    I was looking for a quick way to check the output of TV/DVD/video/whatever without firing up the projector; I'll obviously have to think again...
    Bert
  4. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    If you've got an mp with video switching capabilites why not connect one of the outs direct to a tv?
  5. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Ah, we've reached the stage where I reveal my ignorance. What is an mp?
    Bert
  6. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    A badly spelled amp.:clap:
  7. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    Thanks Richard.:blush:
  8. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    Sorry, I should have been able to work that out for myself.
    I don't have any video signals routed through my amp (or through my mp, come to that.) Perhaps I should look into it - though to be honest, I don't even know how many video outputs the amp possesses.
    Thanks for the thought.
    Bert
  9. rhinoman
    rhinoman
    Oct 31, 2000
    2,631
    71
    Herne Bay, Kent
    +33
    What amp Burt?
    My Sony 940 only has 1 monitor out but 1 each composite and svideo, but also has a vcr loop which you can use the out to feed a seperate display as its always live to the selected source.
  10. bxd
    bxd
    Oct 17, 2001
    1,487
    Southampton
    +134
    You can buy a vga splitter/amp/ distributor.
    I can't remember the details (or the price) but you could look to see what CPC has.
    We use one at work to feed the output from a proV (XGA theater) to two lcd projectors in a lecture room.
    EDIT : Looks as if the device that we use costs about £130....... more than the ProV.
    Brian
  11. HouseofMu
    HouseofMu
    Jul 18, 2000
    376
    UK
    +13
  12. Bert Coules
    Bert Coules
    Mar 17, 2002
    3,268
    +158
    bxd, thanks for the reply. As you say, I don't really want to spend more than the cost of the Pro-V on splitting the signal.
    HouseofMu, I'll check out that Lektropacks part. Thanks.
    Bert
