Pro scan through a Barco bg808
Discussion in 'Projectors, Screens & Video Processors' started by fatrich, Mar 17, 2003.
Thread Status:
Not open for further replies.
  1. fatrich
    fatrich
    Jun 21, 2001
    2,490
    halifax
    +31
    Roland ,Gordon or anyone in the know can i run progressive scan through a barco graphics 808 (not s).
    i am using a denon sdi modded 1600 dvd player through the htpc (holograph card) + mp1- modded 9500 +5 individual leads bnc to bnc in to the barco.When running sdi and component both are fine but selecting progressive scan the piccy breaks up, any ideas? if i the barco wont take progressive can it be moddified and how much?
    regards
    richard
  2. Roland @ B4
    Roland @ B4
    Apr 11, 2001
    2,238
    Reading.
    +32
    I'm afraid the non s 808 would not take component video progresive or not.
    You will have to use something like a key digital transcoder which will convert it to RGB
  3. fatrich
    fatrich
    Jun 21, 2001
    2,490
    halifax
    +31
    Thanks Roland
    I suppose it will have to wait untill i get round to upgrading the pj with you;) its been 6 months since i last saw you, u must be due a visit soon , with having all this holograph and mp-1 stuff i think my pj could do with a re- calibration can you send me some dates when its convinient to come up to sunny Halifax.
    cheers
    richard
  4. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    Hold the phone......
    Rich: What are you trying to do here? Are you trying to compare the progressive output of the DVD player against de-interlaced and scaled output of your HTPC?
    Gordon
  5. fatrich
    fatrich
    Jun 21, 2001
    2,490
    halifax
    +31
    No Gordon
    i was interested to c if i could run progressive through the hd3 and the barco , component through the denon 1600 looks very good not a lot between that and the sdi, just wanted to c how much extra (if any ) the progressive made.
    your turn;)
    (the cables are great btw the x5 cables does make a difference)
    cheers
    rich
  6. Gordon @ Convergent AV
    Jul 13, 2000
    14,174
    +3,004
    Ah...That's was going to be the next question. The Holo3D card doesn't support progressive inputs. Which is why the screen loses sync. Changing your projector will have no effect on this as it's a PC issue.
    If you have AVIA put up a resolution test pattern and compare SDI against Component. Should see obvious difference I think.
    Glad the Cable made a difference, thought it would
    :D
    Gordon
  7. X3ELS
    X3ELS
    May 20, 2002
    1,151
    Surrey
    +108
    The magic cables strike again ;)
  8. ReTrO
    ReTrO
    Jul 12, 2000
    3,507
    2
    71
    High Wycombe, Bucks, UK
    +59
    We talking 'the' magic cable?
    :smashin:
  9. X3ELS
    X3ELS
    May 20, 2002
    1,151
    Surrey
    +108
Thread Status:
