pro logic on telewest digital
Discussion in 'Cable TV & Virgin Media TV' started by pat clancy, May 28, 2001.
  1. pat clancy
    pat clancy
    Sep 10, 2000
    1,841
    LONDON
    +30
    i have digital cable,but the sound is awful,cant get pro logic from movies etc.
    what sound does ondigital use,mpeg2 or what.?
  2. siymann
    siymann
    All digital tv sources use mpeg2 audio...
    i assume the problem with telewest is that the pro-logic signal is not being used(or sent) or that during the encoding of the audio the pro-logic data is being stripped off (removed by the encoders) for some reason, pro-logic on sky seems ok.
    I don't know about NTL...
    Unfortunalty the Sat/Cable companies missed the boat by not including DolbyDigital into the settop boxes :mad: - whereas they have DD in the USA on cable/sat...
    P.S. it could be your set-top box & or your local feed causing the problem, I would contact them and cause a fuss, as all these companies are lazy B******S.
    Good luck.
    [ 17-06-2001: Message edited by: siymann ]
  3. Guest
    For what it's worth, NTL do give Prologic or something that is the same as, i.e. rear channel mono.
    Sounds pretty good too!
  4. siymann
    siymann
    :mad:
