Pro Logic Distortion
Discussion in 'AV Receivers & Amplifiers' started by rockyglw, Sep 11, 2003.
  1. rockyglw
    rockyglw
    Dec 15, 2002
    99
    +4
    Can anyone tell me why I get distortion on dialogue when viewing video tapes using Pro Logic or Pro Logic 2. I have tried various vcrs and av amps with the same results. It is only present on dialogue and comes from the the front left and right speakers. Have also tried different speakers and high quality cabling. Confused???
  2. Nobber22
    Nobber22
    Jun 6, 2002
    2,977
    Berkshire
    +109
    Could be your amp. Do you get distortion using other sources eg. DVD/Cd player? Try moving the VCR phono lead to another input on the amp. The "VCR In" could have a problem.
  3. Jsinger
    Jsinger
    Aug 26, 2003
    40
    DPLII certainly has problems with anything but the most robust of source signals - as many people who watch Sky TV will have noticed. This might be the problem with your VCR, just a simple question of the signal itself not being 'good enough' for DPLII to work it's magic :(
  4. dunkyboy
    dunkyboy
    Jun 5, 2002
    633
    London
    +6
    If you've tried various VCRs and amps, and other sources don't do this (thus ruling out the speakers), then the likeliest culprit would be the software. Does it happen to all video tapes, or just a few? If it's the latter, then I think they've just been recorded poorly (or degraded over time).... :(
    Dunc
  5. pwiles1968
    pwiles1968
    May 15, 2003
    773
    Leicestershire - England
    +10
    What tapes are they? i.e. pre recorded, Long Play etc.
    As said above probably a source quality problem PLII does seem to be quite suseptible to this. I have seen issues with different channels on sky, kids programs are the worst they seem to be lower quality, I have also had problems with VCR recordings from my sister which she always seems to put on Long Play.
  6. rockyglw
    rockyglw
    Dec 15, 2002
    99
    +4
    I have tried variuous brands of tapes at all speeds. And also recordings in SVHS. The problem is worse in off air terrestial broadcasts such as Eastenders
