Pro Logic and Home Cinema Advice
Discussion in 'Home Cinema Buying & Building' started by JPHCCFC, Jun 5, 2004.
  1. JPHCCFC
    JPHCCFC
    Jun 5, 2004
    225
    +3
    Ive just bought the sony HTK250 home theatre. I have a dolby pro logic phillips tv. The tv has a red and white av output. I plug in the audio cable from the tv and connect to the amp. When I set the amp to auto detect the sound it produces stereo Front left and right output. When im watching programmes that are broadcast in pro logic the rear speakers dont seem to work as per expected. Can the red and white audio outputs produce dolby pro logic to the amp or am i doing something wrong on the set up??? I have dolby pro logic selected on the tv and also select it on the amp.
  2. Hawklord
    Hawklord
    Feb 15, 2003
    3,572
    4
    Aldershot, Hampshire
    +313
    Your amp should take the stereo signal from your tv (red and white annologue interconnects) and process the signal to give you prologic (if it has this functionality). Have you tried selecting prologic on your amp as the reciever will only detect a stereo signal if you use auto from this source.
  3. JPHCCFC
    JPHCCFC
    Jun 5, 2004
    225
    +3
    I had the dolby pro logic on the amp selected today for the england iceland match, i was expecting to hear the crowd in the rear speakers as i used to with the tv rear speakers but unfortunateky nothing?
  4. Devil On Your S
    Devil On Your S
    May 24, 2004
    1,652
    Lincoln
    +159
    I've got the very same system today and have it set up the same way as you. All you have to do is set it to dolby pro logic II and hey presto, off you go!
  5. matty2767
    matty2767
    have you set up your speaker distances etc.
  6. gagde
    gagde
    Jun 12, 2004
    152
    +3
    how do u set that up
    garry
