pro line dv 2000
Discussion in 'Blu-ray & DVD Players & Recorders' started by russell williams, Feb 18, 2001.
  1. russell williams
    russell williams
    Dec 4, 2000
    62
    pontypool
    any news on the pro line dv2000
    is it multyregion and will it play ntsc discs as pal
    also aney news on multyregion slaystation 2
  2. track_man
    track_man
    How to convert your Proline DVD-2000 player into a multi-region compatible machine
    Note that this hack will ONLY work until your player is unplugged from a power outlet, after which time it will need to be re-applied
    Reports indicate that newer versions of this player's firmware may not allow playback some Region 1 titles from Warner Brothers
    To convert this player to Multi-Region
    1. Press the Menu button on your remote control
    2. Press the buttons 1, 6 and then 7 on your remote control in order, one at a time
    3. Press the Mute button on your remote control
    4. Exit the Menu and insert the disc to play
