Pro-ject record box e vs Rega mini a2d
Hi Friends,
Just got a Pro Ject Debut Carbon Evo last month and started my vinyl adventure.
Next step: digitalise old vinyls. So i read about this two solutions, since my amp doesnt have usb output.
Id like to read about your opinions pro ject record box vs rega mini a2d.
I know theres also a 3rd choice: Nap pp4, but its a bit pricey.
Regards
ShanePJ
AVForums Sponsor
You also have one by Pro-Ject which is the Phono Box USB MM/MC (which you maybe calling the record box :)) . The manual shows you can record to DVD quality which is the same as the NAD PP4 as its a little cheaper
First of all lemme thank your reply.
I was talking about this:
To be honest it seems very very similar to the one you shared.
Im also going to use this message to ask your opinion. I my amp is a Perraux audiant 80i, which i think is a very decent one and has phono amp. Would you keep the TT direct to the integrated amp or would you use the pre amp "in the middle" and connect it to a "normal" input.
Regards
Oculus Quest 2 VR headset + Rotel A14 MkII Amp Reviews & Best of the Month
