Pro Evo Option files on the 360
Mickey123
Do you need a max drive to load up an option file to the 360 re the Xbox title pro evo 5?
Can't you just download the option file to PC and then wireless LAN it across to your 360?
Mickey
C
CAFCmatt
Mickey123 said:
You mean you can't swap from PC to 360?:eek:
so would I need a max drive then?
No you need and XSATA which is abut £30, available from play.com and does work fine
Having not done it myself and only hearsay from others it does sound a bit more complicated though.
Will deffo be worth getting though
Mickey123
£30??? Mate thats a ton of money for updating an option file.
Can you copy file to disk and then stick it on hard drive?
Is there any other way?
Similar threads
The Best Movies and TV Shows Coming To Amazon Prime Video in August 2020. Tom's Thumbs.
