pro evo help
Discussion in 'PC Gaming & Rigs' started by gooner#14, Aug 14, 2005.
  1. gooner#14
    gooner#14
    Jul 18, 2005
    481
    hia got pro evo on pc(4) dloaded the wolf evo patch but dont know how to install it, also when playing the game and the screen pans left to right im getting a tearing on the graphics!! hoy do i remedy this?
  2. UrbanT
    UrbanT
    Jan 6, 2002
    13,265
    Aldershot, Hants
    +3,031
    Wolfs patch can look complicated to install. Just try following the enclosed instructions carefully. You just need to get to grips with AFS explorer. Perhaps if you explain how far you get with the instructions, this would give us a clue where you are stuck.
    As for the tearing, this is almost certainly because you have 'V-Sync' turned off in your graphics card control panel. Under the Direct 3D tab, put V-Sync to 'always on', or similar closest option depending on which card you have. This will stop the tearing :)
  3. gooner#14
    gooner#14
    Jul 18, 2005
    481
    2 things ive got a 9800 pro card with the catalyst control centre but cannot find "v sync"??
    and ive only downloaded the wolf patch not done anything with it but cannot find any instructions so i havent a clue where to staart
  4. UrbanT
    UrbanT
    Jan 6, 2002
    13,265
    Aldershot, Hants
    +3,031
    I have ATI cards, but don't use the Control Centre. From memory, you should have a 3D panel, then under Direct 3D and Open GL you can adjust the options. On mine, it says 'wait for vertical sync', which you need to change to 'always on', or simply 'on'
    If you have downloaded the whole Wolf patch, there is a 'Read Me' file which confirms where to drag and drop the replacement files to. If you look in the 'Patch Update' folder, there is another text file called 'Update' which has all the relevant instructions regarding the AFS EXplorer part of the update..
  5. gooner#14
    gooner#14
    Jul 18, 2005
    481
    have looked in the folder but cannot find a read me file!!!
  6. Kopite4Ever
    Kopite4Ever
    Mar 15, 2004
    4,373
    71
    Liverpool: European Capital of Football 2005/2006
    +76
    right im abit of a veteran at this and had my fair shair of problems in the past. post a screen shot of the files you got from the wolf's patch so i can see what you have and i will hopefully tell you how to install it. for PES4 there is a new better patch on evo-web called stadium lovers. tried it myself and it was great but WE9 on ps2 keeps me away from PES4 PC.
  7. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    West Midlands - Stourbridge
    +332
    gooner,
    Does your patch just come with 2 or 3 files, and weigh in at about 500MB? If so, just copy the patch files to your pro evo directory and overwrite the duplicated files. I only installed and patched PES4 yesterday, and that worked fine for me.
    Rob
  8. gooner#14
    gooner#14
    Jul 18, 2005
    481
    hi ive got the
    #wolf 2005 evolution patch
    which has 7 parts
  9. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    +332
    If they are 7 .rar files, you need to extract the contents to a folder on your PC. (You will need winrar installed to do this).
    Rob
  10. gooner#14
    gooner#14
    Jul 18, 2005
    481
    then what???
    is there an instruction file any where
  11. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    +332
    Well, have you extracted it yet and looked?
    I am quite sure that there is a readme file, but all you have to do is simply copy the extracted files to your Pro Evo directory and overwrite the existing files.
  12. gooner#14
    gooner#14
    Jul 18, 2005
    481
    done it ta
    is there any way to up date the patch
    davids>>> spurs
    HLEB>>>>ARSENAL
    swp>>>BORING
  13. Pulsar
    Pulsar
    Jan 19, 2003
    3,137
    +332
    Hi.
    I think you may be able to make the changes manualy if you are so inclined. Otherwise, you will just have to wait for a newer patch, but tbh I don't see this happening until PES5.
    Have fun!
    Rob
  14. Pbryanw
    Pbryanw
    Nov 15, 2004
    1,524
    N.E. Lincs
    +101
    Just wondering if anyone's used the Obsession patch for PES4? I 've heard good things about it and it's supposed to be the next best thing to Wolf's Patch as well as being more up to date concerning transfers.
