Printing Pictures Problem
Discussion in 'Microsoft Windows' started by aet3, Aug 26, 2013.
  1. aet3
    aet3
    Feb 25, 2009
    625
    Colchester, Essex
    +15
    Laptop running Windows 8.
    Printer - Epson 235W Printer, set up Wireless.
    I can print documents, test page etc - no problem.
    BUT, when trying to print a Photo using Epson Easy Print.
    Everything runs, a message "Printing" appears.
    Then a message "Printing Complete" appears.
    NOTHING has printed.
    Then a message appears "Printing Error" - not connected !!!!
    I just cannot find where to look or what to check.
    HELP PLEASE.
    Cheers.
  2. SUMMONER
    SUMMONER
    Apr 4, 2009
    1,399
    London
    +251
    Check if you are able to scan, if that doesn't work either you have point the Epson software to the printer. Click start, All Programs, Epson... and look for option called add device or similar.
  3. aet3
    aet3
    Feb 25, 2009
    625
    Colchester, Essex
    +15
    Thank You for your quick response.
    It is my neighbours new Laptop/Printer etc.
    I will go and check and try your suggestion.
    It is strange it prints everything else wireless, no problem, so the printer must be recognised.
    Cheers.
  4. aet3
    aet3
    Feb 25, 2009
    625
    Colchester, Essex
    +15
    Hi Again
    YES - he can scan - no problems.
    Print - emails, documents, screen, etc - no problems.
    So everything must be OK for wireless printing/scanning.
    It is just Photographs that this problem occurs.
    I cannot understand that it shows the photo is printing and then advises complete - BUT nothing happens until the "Error" message appears.
    Any further help please ????
    Cheers.
  5. SUMMONER
    SUMMONER
    Apr 4, 2009
    1,399
    London
    +251
    That is an odd one.
    You could try removing and re-installing the software.
    The latest version can be downloaded here.
  6. aet3
    aet3
    Feb 25, 2009
    625
    Colchester, Essex
    +15
    Thank You for the "Link".
    We will give it a go.
    Cheers.
  7. aet3
    aet3
    Feb 25, 2009
    625
    Colchester, Essex
    +15
    Hi Again
    YES - It worked.
    Uninstalled the Epson Easy Print Software and re-installed using the above "Link".
    Thank You for your help and advice.
    Cheers.
  8. SUMMONER
    SUMMONER
    Apr 4, 2009
    1,399
    London
    +251
    Glad you got it working. :clap:
