Printing Panoramas
Discussion in 'Photography Forums' started by Underscore, Nov 19, 2004.
  1. Underscore
    Underscore
    Hi all,
    I've just got into creating panoramas using Panorama Tools and various helper applications and I've even printed out a couple at my local photographic shop. At 44p for a 12x4, the price is great but they can't go longer than 12". Does anyone know of anywhere (online, mail order, whatever) that can print pano's of an arbitrary length?
    Cheers,
    _
  2. dolph
    dolph
    Dec 16, 2002
    1,192
    48
    +26
    This was discussed in a previous thread - some shops in the UK will print a standardish size 30" x 20" (I think) - which of course you could trim..
    That thread was here - not sure that we really ever came to any form of conclusion, if you do decide to use any of the firms listed please post back as it's something I'm still meaning to do at some point.
    http://www.avforums.com/frame.html?...ms/showthread.php?t=150185&highlight=panorama
  3. Underscore
    Underscore
    Thanks, I'll let you all know how I get on with any that I try.
    _
