Printing My Pictures
Discussion in 'Photography Forums' started by stewart28, Feb 26, 2013.
  1. stewart28
    stewart28
    Jan 3, 2008
    504
    Glasgow
    +58
    Now that I have got into photography I am looking into printing my pictures.
    I have a HP c5180 multi-function but when I print out anything using either the hp software or Lightroom it comes out really dark.
    can anyone offer any advice.
  2. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    Is your monitor calibrated and are you using the correct HP paper?
  3. stewart28
    stewart28
    Jan 3, 2008
    504
    Glasgow
    +58
    Yes and Yes.
  4. vidjo
    vidjo
    Dec 4, 2009
    261
    28
    +41
    What about the calibration of the printer as it's common to both programs.
  5. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
  6. stewart28
    stewart28
    Jan 3, 2008
    504
    Glasgow
    +58
    How do I do that?
  7. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    Hold your horses. :)
    Print the sample images, it will show whether the printer is the problem or not.
    Use the HP software, do you select the paper type in there? Do you select the actual paper product name rather than just generic photo paper?
    I use a Canon, so am not familiar with the HP software. In the Canon software you can specify the actual name of the Canon paper you are using.
    Are your cartridges genuine HP?
  8. stewart28
    stewart28
    Jan 3, 2008
    504
    Glasgow
    +58
    Ok
    I select the correct paper
    No
  9. eddiewood
    eddiewood
    Dec 11, 2007
    6,722
    +1,145
    Assuming you have done cleaning and nozzle checks, if the sample prints properly then your non-genuine cartridges on HP paper are fine and the monitor calibration is the likely culprit.
    If the sample prints do not print properly, then it isn't your monitor. Try again with genuine HP cartridges on genuine HP paper using the HP software to select the HP paper type.
    Keep your images and LR out of the equation until you have got good results from the sample image. Of course don't edit the sample prints, just print them as is! :)
    It may also be worth checking that you have the current version of the printer driver and HP software.
  10. stewart28
    stewart28
    Jan 3, 2008
    504
    Glasgow
    +58
    I will try sample prints tonight an see how i get on.I also calibrated my laptop screen last night.
    thanks for the assistance
  11. IWC Dopplel
    IWC Dopplel
    Sep 11, 2008
    3,986
    134
    BATH
    +510
    It is also likely your monitor is too bright. Look for 90-100 cd/M2
  12. IWC Dopplel
    IWC Dopplel
    Sep 11, 2008
    3,986
    134
    BATH
    +510
    PS if you are using an icc profile for your printer and inks and still finding a difference with softproofing then there is an additional brightness/contrast adjustment in LR4 in the print menu. When your happy you can save the settings for a chosen paper as a template
  13. wongataa
    wongataa
    Jan 11, 2009
    1,604
    113
    Birmingham
    +552
    Your monitor is too bright. Adjust the brightness so whites look the same brightness to white paper in whatever print view conditions you have. Keep the monitor at this brightness.
    A good starting point is 120cd/m2.
    Your calibration process should let you make sure your monitor is set to the correct brightness value that you have determined above.
